IMO, Id use the center returne line to keep it simple. Have it drill and retaped to fit a larger line if your worried about that.
There are actually quite a few things I would change if it were ME. I would not be running a -10 line to start with if two walbros are enough. Thats a big line to keep pressure up in. Ive seen(and heard) of a -10 setup actually causing more issues since under launch the pumps are working harder to push the fuel up more of a hill in the v8 world, with fairly large pumps.
Id stick with the standard twin line setup with stock return.
But, what you want to do in theory will work, will one end of the rail starve first or will there be other issues to come up to bite you? I cant say, but that kinda goes back to the whole "Id stick with the twin setup"
Standard twin feed setup with dual denso's and a BAP would be a killer setup
