1200 ohm resistor... which connectors on maf plug.?
529 Views 1 Reply 1 Participant Last post by  Quikturbo
i installed the vpc but dont know which connectors on the maf plug to connect the resistor to.... any help is appreciated.... do i even need it i thought it was just to keep the check engine light off.... thanx... Kevin..
1 - 2 of 2 Posts
here ya go Kevin,
stoker6 said:
BUT, make sure the resistor is connected right. Looking at the pins of the MAF connector with the rectangle notch facing up, the resistor goes across the second and third pin from the right.
1 - 2 of 2 Posts
