1 - 11 of 11 Posts
I HAVE 16'' MKIV RIMS ON MY MKIII AND WHEN I TURN ALL THE WAY TO THE RIGHT OR LEFT AND MOVE THE CAR IT GRINDS, CAN SOMEONE HELP ME WITH THIS PLEASE.
Not ur jizz, not ur bizz
go buy 17's or get spacers
press caps lock again and ill see what i can do
Go All Electric
1)Spacers alone .... or 2)steering bump stops and put balance weights on outside of wheel or #) Just bump stops enough to clear weights on inside. 4) You could even grind the wheel down or grind a "nitch" in the ower control arm (not reccommended).
H&R makes some good quality sopacers fro precise off-set correction .. and some other companies probably do too. You need to find off-set of factory wheel .. then off-set of replacement wheel ... the try to find a spacer that will attatch to the wheel and or hub and give you the closest off-set to factory.
http://toy4two.home.mindspring.com/offset.html
http://www.hrsprings.com/site/frameproducts.html
Good luck and best regards.
Go All Electric
mk3turbosupra said:
The spacer size you need is 5mm.. they will work fine.
There ya go! Spacers is the best way to go. You keep turning radius and don't drill/shave anything. It is the way to go ... period.
Love the look of the white on white mk3turbosupra. See my sig .. my rx-7 wheels are white too .... I tihnk I want to polish the lip though ... but the all white looks great IMO.
1 - 11 of 11 Posts
