Fastest Factory Auto
I've currently got 18x10 wheels on the rear of the supra, with 295/35/18 michelin pilot ps2's. The PS2's are worn, and its time for some new tires, I've been reading just about everything on tire rack and I've got a few questions
Currently im using a 35 sidewall, should i go ahead and switch to a 30 sidewall? There are a few more choices in 295/30/18. I have 265/35/18's up front, will a 30 sidewall on the back make the car look funny?
The other option im thinking of is going to a 285/35/18, there are a ton of choices for that tire size, and the Goodyear Eagle F1's ($252 ea) look like they have some really good ratings.
I'm tied between mich pilot ps2's (they seem to do the job nicely), potenza s02's (35 sidewall), potenza s02A (30 sidewall), or the goodyear eagle F1 (285/35/18)
Any recommendations?
Matt
Newbie
What's the offset on the rims?
With the 265/35/18 up front, the height is 25.3, so your best bet is 295/30/18 which has a height of 25.0
Now if you were to run the following setup, the height would be perfect:
255/35/18 (25.0 height)
295/30/18 (25.0 height)
Not sure on the offset of the rims, they were on it when I purchased the car.
As soon as the 265's up front are replaced I'll probably go ahead and get a set of 255's to replace them then..
Any suggestions on the tires?
Matt
Matt
Running 265/295 combo. Why would you think 295/30 would look funny? It's the same overall height as stock. As far as height difference of rubber only, many are running this combo and I personally think it looks OK.
