1 - 3 of 3 Posts
Addict
Parker Fields
[email protected]
Tulsa, OK 74136
336-816-1126
Text/calls are ok
Hello ladies and gentlemen. This 1985 Toyota Celica supra P type is up for trade and sale.
Serious buyers with PM can get Pictures, and Carfax.
Garage kept.
170,000 miles roughly on the chassis.
Known issues current:
PS line to pump needs new hose clamp,
used diff could use seals
Idle tune is too lean currently for warmer temps
small paint issues on front bumper (near DS headlight) and rear bumper(left) can take pictures.
left rear taillight has a chip and crack, but visually looks ok.
New Dr Tweak engine wiring harness
custom motor mounts
Stock cams
Engine managment system
AEM v2
Racepak display
AEM Failsafe
LQ9 Ignition
Fuel System
Walbro 400 fuel pump
Fuel pressure regulator summit
-6 return line
ID 1050cc fuel injectors
Blitz Intercooler
well built IC pipes 3"
Polished MK3 radiator
Turbo-BWS366 Billet .96 AR housing 3" Vband, Turbo blanket
ebay 2JZGTE manifold
TIAL 44mm WG 18psi spring
Custom DP 3" with WG dump pipe to magna flow muffler
Tial MVR 44mm BOV
Suspension
Camber plate
Whiteline sway bars front and rear
Super pro poly bushing throughout
Wilwood BBK Front and Rear
Simmons 17" FR17
-4 x 114.3 bolt pattern
-60.1 mm center bore
-Fronts - 17 x 8 +10 offset 245/40/17
-Rears - 17 x 9.5 +0 offset 275/40/17
4.30 stock rearend
Transmission R154
New OEM seals
Short shifter
New OEM seals and gaskets.
Clarion DVD/bluetooth head unit
Tons of Supporting Sensors and parts not listed. You can PM for full list if you want.
All stock amenities work for the most part, haven't check rear wiper, AC not complete.
Dyno car made 467RWHP and 427RWTQ @18psi
Fuel system setup to run E85 with sensor and correct lines, around 30Psi
Car runs and drives. It needs a tune(idle enrichment) , Motor has A/C compressor but no A/c Setup. Heat works. Many parts are replaced/new.
comes with a new power steering rack/ Muffler/ tons of spare parts worth $1,000 roughly
I will answer any questions and take any photos you have.
Car was worked on by Majestic Motorsports in NC and
Niced up Performance and myself.
OLD Chassis Build thread:
https://www.celicasupra.com/forums/showthread.php?68879-New-Well-everything!!!
Price is listed across the internet as 20,000 OBO price is flexible。
I'm open to serious trade offers plus cash
Lexus is250/300/350 cars and
Kawasaki motorcycles
Beautiful car.
Is it E85 only? Or Pump too (flexfuel)?
What power would it make on pump? (Asking because we don't have E85 readily available here in Canada)
1 - 3 of 3 Posts
