1 - 2 of 2 Posts
Asking $12,000 or best offer.
Body
1989 Toyota Supra Turbo Shell
150k ish on chassis, unknown on engine
Clean Arizona Title
Original White package
JDM dark red tails
FD3S RE-Amemiya Carbon Diffuser
bubble sidemarkers
Battery relocated to truck. AGM battery.
Engine
1jzgte VVT-i
1ZZ/1NZ Coils
AEM Infinity EMU
Kaizen Motorsports Engine Harness
Tuned at Soulless Performance
430hp 390tq on ethanol. 350hp 320tq on 91.
Drivetrain
R154
Oem flywheel
ACT 6 Puck Clutch Stage 3
One piece aluminum driveshaft
ACT pressure plate
Polyurethane trans mount
3.73 LSD
Marlin crawler shifter socket
Marlin crawler shifter bushing
Aisin Slave cylinder
High pressure steel braided Clutch line
Fuel System
ID 1050x Injectors
Radium Engineering Fuel Rail
Radium Engineering Fuel Pulse Damper
Flex Fuel
Walbro Hellcat 525 pump
Turbosmart FPR1200 Black
Full -6AN Feed and Return PTFE fittings and lines
E85 Freaks 7 micron filter
Wired for dual pumps
Turbo/Exhaust
AGP Zeta 3.2
.70 A/R hot side
Future fabrication one off Turbo manifold
1 inch manifold spacer
3" Downpipe
Full 3” straight exhaust to dual 4” tip
Tial 44mm MVR Wastegate
Tial Blow off valve
12x24x3 Intercooler
Mac valve boost controller
Stainless Steel AN wastegate Lines
Cooling system
3 core aluminum radiator
Twin 12" SPAL fans wired to relays
Solid upper rad hose
TRD Rad Cap
Suspension and Wheels
Ksport coilovers
Work VS-SS
18x10.5 +24/29
Moog Rear Camber Arms
Interior
Reupholstered Blue Leather
Momo steering wheel
HKB Boss hub
Glowshift Boost Gauge
Lotek 2 gauge pillar pod
242701
242702
242703
242704
1 - 2 of 2 Posts
