IJ. said:1.37mm compressed
It's not a good idea to just presume your injectors are flowing to the upper level of specs... presume they're flowing the minimum unless you get them tested and mapped out.Jeff Lange said:Here are the specs from the TSRM for "acceptable" flow rates, they are going to be a bit lower and a bit higher than the rated flow rates, you'll get a good idea from the 7M-GTE listing.
pre-89 N/A:
260 - 320 cc/min
89+ N/A:
276 - 340 cc/min
Turbo:
404 - 456 cc/min
Hope that helps. The pre-89 and 89+ N/A injectors seem pretty close actually.
