i have a 1991 toyota supra turbo, and im wanting to swap a 2jz twin turbo in, but im not to sure of all the parts i'll need to do it, or how to do it. im buying a 2jz-gtte crate engine along with the tranny, wiring harness, and ecu. and thats about it. any help would be greatly appreciated thanks. :)
theres a thread about this swap. Also its alot more than plug and play as I am doing the same thing. You need new mounting hardware, a 2jzgtte wire harness and ecu, there is some fab work that needs to be done around where the bell housing sits, also a bell housing mod needs to happen if you are sticking to the r154. There is more to the build than people think. It definitely can be done but not so easily its definitely not a plug and play deal.
