Asking 10000 obo
Joel Lima
[email protected]
-Cell number-(323)915-0853
-City- Los Angeles
-California
-90001
Nothing wrong with car just need something bigger for the fam. Has recently had some maintance done to it. Registered & titled under my name.
Body
1991 Toyota Supra Turbo (3E5)
170000 miles on chassis
Bubble side markers
Brand new Euro turn signals
Hid headlights
Euro manual folding mirrors
Motor
2JZ-GTE VVTI (unknow mileage)
Swap was done by Jose Valle at Kaizen
Motorsports new harness as well and all gaskets were replaced. TTC mod. Greddy magnetic oil drain plug. Injectors cleaned & tested fuel pump i believe walbro 255. New spark plugs & Rotella T6 Oil Tundra oem oil filter. (Recent) New oem rear main seal. All this was done with 168xxx miles on car put about 2k my self since then
Interior
cloth shadow grey ok condition could use a shampoo center console & dash need attention.
Cusco rear strut bar
Drivetrain
Factory R154
New compclutch flywheel (14.5lbs)
ACT Street/strip clutch
ARP Flywheel bolts
Oem Throw out bearing
Oem Clutch release bearing
Oem hub washers and retainers
Redline MT90 All less then 50 miles on parts
Cooling System
Oem koyo radiator
New oem water pump
24x12x3 Driftmotion Intercooler
2.75 hot side 3inch cold side nice welding by Jose Valle
Turbo/Exhaust
Stock Twins in TTC mode (Healthy)
Custom 3inch downpipe to mid pipe
HKS Silent Hi Power
Suspension/Wheels
Stance Coilovers
JIC Upper control arms
Rear traction links
Work Rezax ii DDC
Front
18x8.5 +31 235 30 Federal 595rsrr
Rear
18x9 +31 265 30 michellin pilots
Cons
front passenger lower ball joint
Front passenger coilover might need replacing rack has a small leak
  • Price is obo if any real interested partys are considering buyin we can work the price out deduct what needs to be replaced. Also have a ton of parts that will go with this car mostly new oem and aftermarket goodie
  • 246743
    246744
