Hello everyone! I am taking on a new project this winter. I bought a 1992 Supra Turbo Targa with a 2JZ GE motor. I want to move the intake to the cold side, which would require me to remove or close off many systems that run with the throttle body.
I have a new intake (Pictured) and would like to know if anyone has done this before. Has anyone encountered any problems while doing it? What kind of throttle body should I buy?
I have an ECU MASTERS EMU with the PNP harness for the 7M motor.
The motor is currently running on the 7M ECU with an out of date SAFC2 Piggyback. To be honest the car runs like shit. I am ready to give it a good update. Any help with knowledge is wanted!
I installed mine a few months back, but my intake is different than yours. Is your EGR deleted?
Here's a starting point.
1. I'd start by removing all of the ugly stuff, throttle body, Y-pipe, etc.
2. It's good practice to buy a new gasket for the intake.
3. Measure the intake diameter and make sure you get the correctly sized throttle body and gasket.
4. Make sure there are mounting points for the sensors (TPS, etc.)
5. Make sure you make a new mounting point for the hood latch.
Thanks for the tips! I do not think the car is EGR Deleted, given how sloppy this build was for the previous owner. However I'm not sure how to tell. How are throttle bodies measured? in MM?
They are measured in mm. The reason I ask about your EGR is because the 4 vacuum lines on top of stock TB are removed. You'll know EGR is deleted if there are two random plates about the length of your index finger. They look like this below. One will be on the cold side rear of block, and one on the stock intake somewhere. I see you've installed the mani, looks good man. You may have to relocate the PS reservoir to make room for your new throttle body.
They are measured in mm. The reason I ask about your EGR is because the 4 vacuum lines on top of stock TB are removed. You'll know EGR is deleted if there are two random plates about the length of your index finger. They look like this below. One will be on the cold side rear of block, and one on the stock intake somewhere. I see you've installed the mani, looks good man. You may have to relocate the PS reservoir to make room for your new throttle body. View attachment 245983
Thanks! I'll have to check for those EGR plates. what do I do about the solenoids on the side of the factory throttle body that look like they control idle, etc. ? I cannot find a throttle body that has mounting points for those solenoids, and im not sure if I need them.
I hate to ask you to do all of my finding, but if you don't mind do you think you could find a 92MM version of what you previously linked? I cant seem to find any that have the OEM Style TPS Plug.
When you say 92mm are you measuring the OD or ID of the throttle body pipe? Should be the ID, not all the way across. Manufacturers refer to the inner diameter when they sell a throttle body product.
The 4 screw holes on the Q45 TB will not match up with the pre-drilled holes on the XS FFIM, as the predrilled holes on the FFIM are spaced further apart on the flange. 2JZ-GE FFIM SUPRA TURBO SC300 IS300 INTAKE MANIFOLD.
Nah, you have to tap into it to make it work and weld a bung. Since your intake is only 2mm off you could just have someone fabricate an adapter to fit a 90mm throttle body. Hoping someone else can chime in.
Or you could drop some money and get one of these. It comes with everything you need. That's what I did a while back. Intake
If the manifold is like most other Chinese made manifolds out there the TB spacing is going to be based of the Mustang 5.0L throttle bodies.
All said and done you'd probably put more time, money, and effort into getting your manifold setup than you would to just buy the one linked by Supra_Spooler above.
Are you running factory injectors? I worry that my First State Motorsports Fuel Rail with 560CC EVO Injectors will not mount up to any of the intakes that are like the one you linked.
1 2JZ-GE intake manifold. 1 Fuel rail. 1 90MM Throttle body. 3/4 high flow fuel rails: 1 included. Color Bead Blasting Black Anodized. All gaskets and hardware included. Vacuum ports: 4 on the bottom side.
The intake I listed comes with a fuel rail. So, two things here regarding injectors.
1. Our motors are 2JZ-GE's at heart, so you'll need to run High-Impedence injectors.
2. Since you run higher CC's, what you can do is pick up some stock (or aftermarket) 550CC high imp. injectors off of a 13B T2 Rx7. They are plug and play for the 2JZGE as long as you have fuel management.
Recently brought a mk3 turbo and it had a crack in the gauge cluster window, well this morning its decided to extend across and im now thinking of replacing it.
Ive seen a couple of speedometer clusters eBay, auto but should still work, anyone know if you can separate the plastic window off the...
Hi, I have taken my 89 supra out to the track a few times now and I can only do about 3 or 4 full tilt laps until it starts to get really hot and overheat. I've put a new radiator, electric fans, and a shroud, but that hasn't seemed to help. Anyone got any ideas what the problem may be?
(This is a 7M-GTE 5 speed manual, single turbo)
Okay, I got my really weird running rich issue fixed, I got my turbo MBC issue fixed, it ran, it drove, and now we have yet ANOTHER issue. Dear lord help me just get this car road ready.
I finished my 150 mile turbo break in process and decided to...
Can anyone tell me where is the fuel filter located on a 1987 toyota supra turbo. The manual states it is next to the starter. The dealer states it is under the intake manifold. But I still can't find it.
Can't believe I have been a member for 9 years, and this is my first post!
I have an 86.5 Supra hardtop with the Sports Package and 5-speed. Love the car, but it is now in some desperate need of TLC. I bought it 9 years ago with 200k miles, I am the fourth owner but in essence the second owner...
