1 - 1 of 1 Posts
1993 Toyota cresta tourer V (1jzgte ). Car is titled and registered in my name(Nevada). Cash only, no trades. Price is firm.
Originally auto, was converted to manual (jdm mk3 supra r154) . Car is in very good shape and shows 156km on the clock (little over 96k miles). Runs good and pulls hard. Invested over $14,000.
R154 rebuild parts list (done in last 500 miles)
  • New first gear
  • New second gear
  • New 1-2 hub
  • New 1-2 slider
  • New 3-4 slider
  • fully built r154 transmission upgrade (driftmotion)
  • labor done by driftmotion vendor
-redline mt90 fluid
Other r154 parts used
-Beech performance short shifter
-Brian crower poly shifter bushing
  • driftmotion shifter extension service
  • new shifter housing grommets
-Marlin Crawler VSS Vehicle Speed Sensor
Parts used on auto to manual swap
  • Oem clutch pedal and assembly. Ordered through megazip in Japan.
  • aisin Clutch master cylinder from mk4 supra
  • OEM aisin slave cylinder
  • stage 3 competition clutches 6 puck sprung clutch
-Competition clutch lightweight flywheel
-Driftmotion R154 Swap Transmission Mount Kit (polyurethane transmission mount)
  • stainless steel hydraulic clutch line
  • 1 piece custom aluminum driveshaft made by Dan's drive line in Las Vegas
  • OEM rear main seal.
  • OEM pilot bearing
  • spare aluminum flywheel will be Included.
Mechanical
  • New front rotors and pads
  • New coil pack connectors
  • New valve cover gasket
  • New hood Struts
  • New serpentine belt
Mechanically the car has some minor flaws. Slight hesitation when car is cold. This issue is gone when the car warms up. Tires still have a good amount of tread but, will need to be replaced in the near future.
-Interior
Interior is complete and looks good . New shifter and e-brake boot.
-Exterior
Body is straight no rust. Paint shows minor fade and minor rock chips-dings but, is in good shape.
Al 725-208-7258
1 - 1 of 1 Posts
