41 - 60 of 87 Posts
Is this on shitty 91 octane? Could that have anything to do with it? I remember adding 2-3mph to my traps by simply running higher octane (100 unleaded) gas and resetting the ECU.
I know mine is on 91 octane
Going for broke
Even with a worn out clutch and tons of slipping, my BPU destroys similar cars. Can't keep traction for the life of me, even at 40mph roll. I'm also TTC with WG spring mod, fmic, intake, full exhaust and bleeder T to make the 16psi. None of my vac lines have been replaced (all from 1997) and my front main seal is leaking (lol, time for timing belt job). But, you should have walked that 350z no problem.
My supra is is full bpu and I cannot break the tires loose at all! I am running the BNR twins, 3600 stall, fmic, fcd, wg spring with spacer on the wg as well, 3" dp, 4" hks ti running 15-17 all day long and still can't beat a 02 wrx lol
maybe its driver error?
Mind if I do a J?
WTF!!! Where in Cali are you?
MMA you free any days Monday through Wednesday this coming week?
I might be able to meet up with you sometime then, you are about an hour and a half away from me. Do you have any suggestions on what to look for or where to start? I believe I have tested just about everything except for doing a smoke test for leaks.
Mind if I do a J?
I was considering heading down to San Diego to meet up with MMALifestyle and see his car during those days. Are you near SD or in between Palm Springs and SD by any chance? I'm not an expert by any means but I did some good work on my car when it was BPU and feel comfortable with being able to help you guys solve some issues and find out where all your power is going!
I am in between the two. Okay cool because I have tested just about everything and it all seems to be how it should haha
Mind if I do a J?
MMA what's the deal? I'm headed to San Diego tonight. Shoot me a PM if you want to meet up.
Holby same deal. Wanna meet up in SD or maybe on my way home Wednesday night? Where are you exactly?
Yeah, I will let you know! I am in Temecula/Murrieta area.
Reverend Hillclimb
Discussion Starter · #51 ·
My bad my man, im in detroit. I wish i could. I wouldnt mind coming up to where you are.
Never have shit to do after work anyways.
Same goes to you, always down for some repairs.
Funny thing is before i left i took the car out. I destroyed a g35 out the water. Maybe i wasnt really all out during the 350z race since my stock suspensions was causing rub and i was paying more attention to the noise than driving
Mind if I do a J?
All good, next time! Had a great night downtown last night.
Holby I'm cruising through Temecula on my way home tonight. Shoot me a PM if you wanna meet up.
Raising the BAR
Granny shiftin, not double clutchin like you should.
Raising the BAR
Honestly Im just gonna go single and call it a day since im bored messing with these twins anyways
fuck it
It was a joke, but yes, a single is the way to go IMO. I tore my twins out as fast as humanly possible.
Reverend Hillclimb
Discussion Starter · #57 ·
I wanted to finish my whole single build at once, but that would be $$$$$ so Im gonna go single with stock components for the time being and buy the other stuff as it comes by.
not yet though, I want to turn these twins into mulch, then ill do it
I just pulled my twins over the winter and installed an SP Torque Monster kit with 6266 and QSV. Im on stock pump and injectors and made 456whp on SP's dyno. Car pulls waaaay harder than my BPU set up did(wasnt tuned for BPU tho) You will be very happy once you do the same dude
Sent from AutoGuide.com App
Reverend Hillclimb
Discussion Starter · #59 ·
Batman drives a supra, I always knew it
41 - 60 of 87 Posts
