Hi guys, hope someone has had experience with aftermarket Camshaft position sensors from Rockauto.
I recently did some work on my new to me Supra:
replaced all ignition coils and spliced in new connectors
replaced all injector seals
replace intake manifold seals
EGR delete (with block off plates)
and replaced the cracked Camshaft position sensors with these (More Information for ULTRA-POWER PC215)
which are a fraction of the cost of OEM (i know i know, always use OEM parts)
Put everything back together after cleaning it up etc...
Cranks, has fuel, has spark, but does NOT start.
Yes the car ran before but did not hold boost(i found an injector seal to be leaking) main reason i ripped this thing apart in the first place.
no DTC codes.
before i rip back into it and try the original sensors, i wanted to see if anyone else may have had a similar experience with aftermarket sensors where you have a spark and fuel but the engine just doesn't run and there are no codes.
Any constructive input is MUCH appreciated!
thanks
no DTC codes.
thanks
