Friend of mine is selling his car, I can vouch for him, his car is very fast and he drives it daily! can't beat it!
Mods:
Custom 383ci LT1 with MANY Modifications
Engine Mods: Built by www.theengineworks.com
Dyno proven 400+ rwhp(have dyno sheet)
Block, square decked and align honed, splayed 4 --bolt main caps
SCAT Forged crankshaft
Eagle H-beam connecting rods
JE Forged flattop pistons
Rotating assembly balanced and blueprinted
Ported and Polished LT1 heads
Stainless Ferra Valves 2.0 intake 1.6 exhaust,
--3 angle valve job
Comp Cams pro magnum rocker arms 1.52 ratio
hardened pushrods, custom seat pressure comp --springs, titanium retainers
Custom ground solid roller camshaft
--(260/260 @.050 112LSA .618 lift with 1.52 RRs)
BBK 58mm Throttle body
Ported LT1 intake
K&N FIPK cold air
Lucas 42 lb/hr injectors
Jet Hot long tube ceramic coated headers
NGK TR6 spark plugs, Taylor 8mm ignition wires
MSD blaster coil, MSD Digital 6 ignition box
CSI Electric water pump
Mufflex 4inch race exhaust w/ mufflex muffler
Racetronix.com 255gph in tank fuel pump
Canton Road racing oil pan, with baffle, crank scraper, kick out, and trap doors to keep oil where it belongs
Transmission and drivetrain: www.artcarr.com
Art Carr 700HP+ 4L60e, Art Carr 4000 stall 9.5inch --torque converter, B&M Transmission cooler, Deep sump pan
Spohn 3 inch extreme duty steel driveshaft from www.spohn.net
Moser 12 Bolt rear, 33 spline axles, 4:10 gears
Suspension and wheels:
Spohn chassis mount adjustable torque arm w/ driveshaft loop
Spohn 1 inch rear sway bar
Spohn rear lower control arms
BMR boxed subframe connectors
BMR front strut tower brace
Aluminum Polished ZR1 wheels 17x11 rear w/ --315/35/17 Nitto Drag radials
Fronts 17x9.5 w/ Kumho Ecsta Z rated 275/40/17
Other mods:
LT1_edit v2.2 for tuning PCM
Pioneer CD/MP3/XM head unit
Kenwood speakers
Custom Artic white paint job with blue pearl (absolutely stunning
www.tripintaz.com/ebay.htm
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=6427&item=4537407615&rd=1
You can IM him directly tripintazx or just e-mail him [email protected] He wants 11.5k for the car.
Mods:
--3 angle valve job
Ported LT1 intake
K&N FIPK cold air
Other mods:
Kenwood speakers
