Who out there has installed trev's ypipe and dp....i have got everything installed but i cant figure out how i will bolt down the very back lower bolts ...there's no clearance for a bolt...and theres no clearance for a nut..any ideas here guyyz?
are you talking about the bolts for the turbo exhaust flange to the y-pipe flange? i didn't even bother putting those back on. there's no way it'll fit.
have you tried using a longer stud? if theres no room for a stud, you can always drill a bigger hole on th y-pipe flange. thats what I did, no exhaust leak here :)
"are you talking about the bolts for the turbo exhaust flange to the y-pipe flange? i didn't even bother putting those back on. there's no way it'll fit."
do you have an exhaust leak b/c you didn't put the back ones on?
Im kinda lost now, but if it helps I think I ended up using 3 turbo gaskets on each side and started the nuts on the indented sides of the Y pipe first.
