1 - 17 of 17 Posts
5-speed r-154 with super low miles. Sourced from jarco, and perfect. No suprises. Has 1jz bellhousing, can be sold with 7m housing if desired. Comes with stock clutch, and pp. 750.00 with 1j housing
Twin plate os giken for 1jz. resurfaced, new disks, w/conversion kit. *SOLD*
cherplex said:
Is this from a soarer of mkiii?
the clutch, or the trans? The clutch would work on the soarer, or supra. The trans would have to have the shifter assembly extended to work on the soarer.
will the twin disc work with the r154 with the conversion kit for a mk3?
Discussion Starter #8
this clutch originally came out of a t-78 1j car with r-154. It would work perfectly.
what's the conversion kit?
The conversion kit is what converts the tob, and fork system to a push instead of a pull. It is reuired on all osgiken clutches for the r-154 that I am aware of.
PM sent
Not so boring anymore
rdColGA said:
will this tranny with the 1jz bell housing bolt up to a 2JZ?
yes
do you have any pictures of the transmission? and does it have the input shaft and clutch fork still attached?
1 - 17 of 17 Posts
