1 - 2 of 2 Posts
After a few miles the car is acting funny
At 0,5 bar (Used to run 0,7) it cuts out
What can be the problem?
LAG?? Learn to drive...
first of all how are you running 0.5bar ~7.24psi when the stock boost is 10psi. now 0.7bar is ~10.14psi. this is stock boost, and if its cutting out, then one of a few things are happening.
one your boost gauge is broken and you are runningmore psi than you think and hitting stock fuel cut.
two you blowing out the spark, try running your plugs between .25-.28 thousandths. see if that helps
1 - 2 of 2 Posts
