1 - 8 of 8 Posts
Thinking Person
really now? both of those cars had the same motor too...
you didnt mean jza70 and jza80 right? because that had more to do with the initial question
Well, the JZA80 and JZZ30 share the same style cat, but the length of the DP is different and i think the bolt pattern for the 2jz differs from the 1jz. The JZA70 has a completely different type of downpipe that extends under the car where the JZA80 and JZZ30 ones stop. Thats on the J-spec models though, not sure about american MKIV supras
really , i was just wondering because i found quite a few aftermarket 2jz downpipes and i figured if i cut the dp till where i need it and i could run the rest to the back @ 3inches.... but i think the 1jz is a reversed 3 bolt pattern on the dp...
Thinking Person
so i guess on a jzz30, you need the jzz30 downpipe?
1 - 8 of 8 Posts
