1 - 7 of 7 Posts
yeah thats me!
what kind of damage will that do to my wallet :sadance:
for r154 fivespeed
-ian
1JZGTE engine parts
overhaul gasket set $ 138
cam cover gaskets $ 15 each
main bearing set .25mm $ 160
rod bearing set .25mm $ 78
flywheel $ 223
timing belt $ 21
T belt tensioner $ 46
starter $ 179
bellhousing for 7M $ 300
cam seals $ 5
rear main seal $ 25
oil pump seal $ 9
head bolt set $ 145
valve stem seal set $ 75
ignition coil set $ 384
crank position sensor $ 71
cam position sensor $ 71
Most 1JZ parts are available special order.
Jeff
1-800-327-2087
thats a cut and paste from his 1jz parts sticky...hope it helps....shows the flywheel at $223
i just ordered a bunch of 1jz parts and everyhting was perfect from Jeff.......i highly reccommend him
1 - 7 of 7 Posts
