1 - 4 of 4 Posts
hey wats up guys.....i have a 86 mkIII and i have a automatic 7m-ge motor and im wantin to buy a 5spd 1jz-gte complete swap from ecu,ac pump,to power steerin pump the whole 9 yards...but the reason i need help is cause im tryin to get my background info before i do the swap like on other forums every body says the swap will only work on the 89-92 so that on the 86-89 i would have to relocate the motor mounts is that true???and i know wat i need to swap the motor from a (drive shaft,pedals,master & slave cylinder,clutch lines,and motor mounts) am i missin anything???i seriously need advice please help...wat else will i need to make this swap work.....please help me any advice would be appreciate thanks for takin ur time for ur help..........
1 - 4 of 4 Posts
