how long does this take and is it a PITA. Second, im using a complete 1j h20 pump and hudraulic pump set up from a member on here, do i need to replace any gaskets.
~scott
~scott
Not sure exactly why your using that weirdass pump, I think the hydrofan is way overrated. I would definitely replace the gasket where the pump meets the block, I don't know if a 2J gasket would work or not. Since it is a rear wheel drive setup the water pump is not that difficult to get to. Pull that hydro fan out, put a new 2JZ pump, get some electric fans and free up tons of room, just my .02.scottiedawg66 said:how long does this take and is it a PITA. Second, im using a complete 1j h20 pump and hudraulic pump set up from a member on here, do i need to replace any gaskets.
~scott
