Hey,
so ive made a bit of progress on my 1jz+e6k 240z. Ive gotten the engine to fire and run for about 2 seconds. I do not have a noise filter on the ignition, so this may be my problem. I had to run the trig advance at 45, home gain at 6 and trigger gain at 3 to get it to run for this brief period of time. I did charge the battery as much as possible before starting, took it for a 30 minute drive, but toward the end of my trials I think it was starting to die again
Odd problem to diagnose,
sometime when firing, then engine would sound like it was healthy and wants to take off but then the ecu will die, the laptop says reconnect haltech and the last recored values are 500-600 rpms and the battery voltage around 11. Is there a common problems this may be caused by?
If anyones got any ideas let me know!
