I have a 92 sc300 1jzgte Well today i decided to extend my wiring harness from the ecu because i needed the ecu to sit a little lower. Prior to my extension of the wiring, my car ran good. Now it idles at low rpms and the car has no power whatsoever......ANY IDEAS? iLL POST A VIDEO OF WHAT ITS DOING LATER ON TONIGHT;
supra love
how far did you extend it and did you extend it right by the ecu or where at. check engine light on? did you check the new wiring?
did you use sheided wires for the knock sensor? if not that might be your problem.thats why you dont extend the ecu harness ,its only problems
I extended it by the ecu and extended it 8 inches ....what else could be the problem.?...I also used shielded usb for the 2 brown knock sensors
JetFire
I was going to do the same thing but found a patch harness from Autosport Wiring it's about 200 shipped but worth it. I can patch in whatever I need and the ecu will sit in a better position.
