1 - 20 of 51 Posts
HMOOB VWJ NYOB MINNESOTA
1JZ Joined 500 RWHP Club Today :D..(video)
Took the car to the dyno today and it did O.K. :bigok:
Here are a couple dyno sheets tune at 14 psi on 92 pump gas.
And here are the other dyno sheets tune at 27 psi on 114 octane leaded fuel.
SAFC is at "0" from 5k-7k in the 540 run.
Specs:
T-66 with 3in DP to 3in Exhaust
Home Made Clutch (combine parts from rps 3200lb and act stage 2)
mk4 550 injectors
walbro pump
S-AFC
Bone Stock Motor including cams and headgasket
Looks like I will be needing more fuel + cams + ignition and we will see what happen then.
Republican
Very cool!!!!!!! 27 PSI with 550!?
LAG?? Learn to drive...
somethings wrong with your link, shows a big page of weird writing
This Is Why I'm Hot.....
IdealSupra said:
with those AF numbers and the fact that your at 546 with just 550s...id be a little weary....
nice numbers though ;)
WEARY means to be too tired. I think you meant WARY, which means to be cautious.
Word selection aside, your message is pertinent. With those AFs, I'd pull the spark plugs and look for speckling, to err on the side of caution...but anyone who is capable of those dyno sheets and drove it home, already knows this. The way those curves plateau & practically level off to the end of the chart is beautiful.
Enjoy the car, but please be careful. I'm a dad, so I had to say it.
Take care.
Discussion Starter · #17 ·
Take care.
Thanks for the kind words, I'm only driving around with 14psi.
83'Mk2L said:
[Like I said I need a ride in that thing.
Maybe one day, but only on low boost though ;)
I hope the link works for everybody because it work just fine for both of my computers.
Republican
yes... me too. Im upgrading right now to 550's.. then ill go big style and get top feed's....
1 - 20 of 51 Posts
