1 - 18 of 18 Posts
This is the mod list, I kid you not :)
the car has stock ecu, 440cc injectors, FCD, GT35/40 4" dump into a 3 1/2' exhaust, walbro pump, SX fuel pressure reg running 60psi base pressure!! And thats about it.
It hits rev limiter up top. This is on a dyno dynamics dyno in shootout mode so add some more if you were to compare to dynojet :)
This car defies logic to me.
it isn't my car, it is a guy I know.
Yeah, the A/F is on the limit for sure.
The 440's theoretically shouldn't be pushing this much power and that is why the AF is low up top. He also has made 360rwkw on stock injectors.
The spike is where it hits rev limiter
Moderator, l337 M0d3r4t0r
Simple.. you guys are forgetting 60 BASE Pressure I'm guessing he was running 25 ish PSI so 60 + 25 = 75 PSI of fuel pressure spraying though them poor injectors.
But if you watch I bet it detonated and the knock sensor picked it up at 545 then drops off to 420 because timing was pulled and such. As it catches its breath again and then as it bulids power gets progressivly leaner, until he hits redline.
I'm sure thats what happend here, but it's really only speculation since i wasn't there.
Eaither way very dangerous, if he ran that on the street like that ONCE he'd blow his engine that i'm sure of. but nice numbers none the less..
Tell this guy to spend 400 or what ever to get proper size injectors already.
The dip in the curve at the end is where it hits rev limiter.
The owner had his head right on the engine listening for pinging and couldn't hear any. That's not to say that there wasn't any, but not enough to be audible.
That is on 28.6psi.
Made 331rwkw on low boost, can't remember what that was though.
The car is daily driven :p
I would have thought it would have blown up by now as well but it just hasn't? Obviously running it in this state of tune is not the best for longevity but this guy has 4 spare engines anyway.
I have a vid of the dyno run if anyone wants it?
BTW isn't 60 +25 = 85?
sorry your right 85 ;)
Learn me to add.. lol
Anyways, when my base was 50 PSI on my walbro on 550's I had to remove 20-28 % signal from my system to keep from being rich when I did 445 to the wheels.
Anyways, still I'll put money down that he'll blow his engine if he runs it exactly how it dynoed on the street.
Not so boring anymore
damn, 550s that hard to come by over tehre.. that is crazy..
good numbers though
1 - 18 of 18 Posts
