Well, I must admit . This is the easiest swap I have ever done. In 1997 I was the first to do sr20det swap on the East coast and found out the hard way what to do and NOT to do. Well with this swap no body mods are required to install engine and stock intercooler piping. All the holes are there and bolt holes tapped. I started removing stocker at 5pm and finished completely installing 1jz 5 hrs later. I didnt even have to remove hood !!!
After I was done I must have looked over the car 5 times thinking this was too easy I must have missed something. but it was all right. from the heater lines to the power steering nothing was an issue. Im surprised more of these aren't on the streets for the simplisity and cost. I got this engine complete from www.jhotexports.com for $1200 . The wiring harness does need to be made 18" longer to allow the ecu to rest in its place. I have not gotten to the wiring inside yet but the outside plugs color match and plug right in. as soon as I get the throttle cable and ecu Ill let you guys know how it goes.
