1 - 9 of 9 Posts
· 7M POWAH! baby ;)
hey ya'll... i've decided to get rid of the 1uz throttle body being that i couldn't figure out how to mount the cable nicely for the throttle linkage
so now i need to know how to make a 1jz tps work on a 7m harness
so can someone write up how to do the wiring changes?
Thanks alot :D
· 7M POWAH! baby ;)
Discussion Starter · #2 ·
doesn't anyone know :(
yikes
you have a pin out of the 1jz tps? That would help alot. Or a tsrm would be better.
ok
seems like they use the same signal just labeled differently
1jz tps
IDL2
VTA2
VTA1
IDL This is probably the same as IDL on the 7m TPS
7m TPS
Vcc +5 VDC
VTA Signal
IDL on/off for idle
E2 Ground
as you see i got most of it. I can not tell from the diagram what VTA 1 and IDL2 are. Though it should be easy enough
with a multimeter
Process of elimination.
With throttle closed
contect to
VTA1 and VTA2,
IDL2 and VTA1.
IDL2 and VTA2
throttle open
VTA1 and VTA2,
IDL2 and VTA1.
IDL2 and VTA2
IF IDL2 and VTA2 stayed the same in both position. Either ILD2 or VTA2 is the ground
IF VTA1 and VTA2 resistance increased by going from closed to open. Then either VTA1 or VTA2 is gorund
Because of step 1 VTA2 MUST be ground.
This means that IDL2 is more than likely the 5 VDC while VTA1 is the output signal:)
if that is the case
VTA1 = VTA on 7m TPS
VTA2 = E2 on the 7m TPS
IDL = IDL on 7m
IDL2 = E2
now It would be cleared if I had a 1jz tps infront of me but this should be close.
· 7M POWAH! baby ;)
heh i just woke up (late morning lol)
and have skimmed it just now... and wow i'm confused haha
but i'll come back to it later today once i have myself a 1jz tps to test with :D
thanks for the info, much appreciated ;)
· 7M POWAH! baby ;)
LMFAO
umm nope not 8am
it's 10.20am haha
geezes!!
wow you did really sleep in :)
btw the step i gave you apply to the other 4 pins
it is a process of elimination.
1 will be on/off switch. that is the IDL on the 7m :)
1 - 9 of 9 Posts
