1jz-gte motivation
I was trying to get a general bearing on turbo spool and efficiency pertaining to the pushing power of the 2.5 liter 1jz (or the 1.5jz if interested).
I was looking for people to comment with there setups so they can all be available on one page. Easy searchability will help others later. Now, this thread is meant to be for informational purposes and not for debate. If you could please post your supporting mods and the turbo you went with I would appreciate it. Also, many would be interested to see at what RPM you hit what level of boost and also, what RWHP numbers you have made. Octane of gas and boost level also please. If you can think of any other valuable information I have left out pertaining to your setups please add it, but try and keep it in the format that follows. Thank you.
Format should look somewhat like this:
Motor:
Turbo:
PSI:
Supporting Mods:
Octane:
Spool specs:
RWHP:
Not so boring anymore
Motor: 1jz stock
Turbo: 67 p trim .70 ar
PSI: 9
Supporting Mods: aem, front mount, ic pipes, 3" exhuast, 550s
Octane: 93
Spool specs: 4000-4100 full spool
RWHP: ~ 330 id say, still need to get on the dyno and tune it..
Motor:1jzgte
Turbo: Garrett GT40/67
PSI:8
Supporting Mods:HKS 272's mild ported head 850cc injectors TTC fuel rail.
Octane:93
Spool specs: .68A/R 8 psi. at about 3900rpm
RWHP: 389 whp at 6000 rpm more tuning to do.
1jz-gte motivation
For christ sakes...Come on guys.
