1 - 1 of 1 Posts
So I’m upgrading a 1jzgte vvti to put in an e36 and can only find arp head studs for a 2jz not 1jz and need to know if the 2jz arp head studs would work on a 1jz. I’m also not sure on what thickness of head gasket to get as an aftermarket from tomei because they have a stock engine spec chart and the stock thickness is 1.2 mm and they only offer 1.5 mm, 1.8 mm, and 2.0 mm. I’ve heard that increasing the thickness decreases compression a little bit which allows you to add more boost in but I don’t know what size to go for.
1 - 1 of 1 Posts
