1 - 2 of 2 Posts
Hey I have an oil leak coming from my oil filter housing, I have the new seal to replace it, what I want to know is how hard is it to remove this housing? How many bolts is holding it to the block or how do you remove it from the block to change the o-ring seal. Ant help would be appreciated as I’m looking to attempt changing the seal this weekend. Thanks
Fairly easy, a few bolts and one big union bolt that I believe is 24mm. There are pipes in the way, so it can be a annoying. I also suggest preemptively draining your oil so you don't have a huge mess on your hands. GL
1 - 2 of 2 Posts
