1 - 4 of 4 Posts
as the title says, I have searched the forum to no avail. Is the Ignitor module the same for the regular and the VVTI version of the 1J?
Dr. Jeff Lange
No, the VVT-i 1JZ-GTE uses wasted spark with 3 ignition coils, versus the 6-coil sequential ignition setup the older versions used.
The VVT-i 1JZ igniter is the same as the 98 Supra N/A, 98-00 SC300, 01-05 IS300 and 98-05 GS300.
(Part number 89621-30020 and 89621-30030 will work.)
Jeff
Jeff
thank you very much good sir!
I’m in the same boat buy a 1jzge engine vvt-i and the engine beside the left cam have that’s wire cut I think that one it’s te igniter one some body knows where can I found they conector with the ignitor
259016
1 - 4 of 4 Posts
