I finally finished installing the T78 and the fuel system So I decided to drive the car to work this morning. What happens...the oil light came on. I pulled over and noticed that oil was everywhere on the underbody cover. I added another quart of oil and the light went away for a minute before it came back on again. So I turned around and headed back home...big disappointment. I have not had the chance to find out exactly where the leak was coming from. It was definitely from the turbo side of the engine. Any ideas what can cause such a fast leak? Oil feed, oil return from the turbo, oil plug to second oil feed?
I also ran into a second problem...the car hesitates or bogs under 3k rpm at times? Is this normal for car that has not been running for a while with the batery disconnected?
Thanks, any help is appreciated.
