1 - 3 of 3 Posts
for a 1stgen 1jz.. would it be legit to plug off the hole on the y-pipe and run the line off the exhaust valve cover to an area between the Y and air filter? I drew it up.. This seems like it would fix the problem with the Y not providing good suction on the hose. Anyone know?
Trev
hmm, well, it is ending up in the same intake track. I supposed it should be okay, but this won't solve the problem of the PCV failing (I believe) so i would imaging you would still want to take care of that. At that point, once you replace it, it is just more work to add a bung to the intake to attach the hose.
Trev
just get a $40 catch can...they're prolly cheaper now..check ebay :)
1 - 3 of 3 Posts
