In May I'm going to be attending a weekend long Solo1 course. Is there anything I should do to prep my car?
Any general advice for someone who's never done this before?
Kevin.
Depending on the track, you'll need some different brake pads - try Hawk blue for a track that's hard on brakes, Hawk HP+ for a less severe track. If you're running street tires with alot of tread depth, you may overheat them. Do a good compromise street/track alignment if you can: - 0 toe front, 0 to 1mm toe-in rear, -1.75 camber front and rear, 3.5-5 caster (balanced left and right). Bleed your brakes to have fresh fluid - Motul 600 is a good choice. Have fun, and give us a call when you want that suspension upgrade, you'll see what I mean.
Jeff
Jeff
Thanks for the feedback. I do have an upgraded suspension. I'm running Eibach's, KYB AGX's and the normal TRD sway bars. The circuit is supposidly fairly tight.
So I should swap out my brake pads for these Hawk pads? Can I run them on the street too? Where can I get them?
My tires are Nitto 555's, with alot of tread. (245's up front and 275's in the rear, 18") What pressure should I set them to?
I'm definitely going to get an alignment. Currently it's set to the stock Toyota setup.
Kevin.
Which track are you planning to head to for the course.
As for the brakes, the hawk pads are a KVR product...Ottawa based company. They have a web site , but phone them, don't bother with the e-mail...they appear not to use it much. :) Best part is that they are Canadian, keeping the exchange monster out of the deal!
http://www.kvrperformance.com
Thanks. The track is Shannonville.
Kevin
