I've been getting some PM's about this setup so I thought I'd post some pictures now and update it later with results.
I used ignition coils from an 04 Corolla which are "smart" coils with built in igniters. I ditched the stock igniter by soldering the wires together and wired in these coils using the stock harness.
The coils have 4 wires (12v, ground, tach, trigger). I used the stock 12v and trigger wiring and ran a ground from each coil to the head. As you can see, they fit under the stock cover nicely.
