Respect
Im remvoing my ac compressor but for som e reason i can't get it off. I"ve removed the two main bolts on the front and the one nut on the back with a dedp socket. What else do i have to do to get it off?
Second question is, how do i losten the belt tensioner for the timing belt so that i can remove the belt?
1400rwhp/8 Sec Club
... i will have to check the AC compressor, i remember it being those 3 bolts, but if its not coming off then there is obviously something else holding it on.
For the Timing Belt Tensioner: Its to the left of the crank pulley.. and u may have to take off the timing belt cover. Its two 12mm bolts that hold it in place, make sure you take them off evenly or you will spend more time tryin to get em off.
hmmm if I remember it correctly there's 2 in the front and two on the side... unless its moving around already there should be 4 bolts total.... good luck...
