1 - 20 of 28 Posts
· Stock Boost FTL
alright so im working around the starter area and i find 2 sets of wires, not sure which is which... one is the loom of wires with an eye connector on the end coming from the battery and the other is the set of brown-white-someother color wires with a eye connector on the end coming from the harness next to the starter... what is what?
IAmAnMKIIIWannabe said:
plus what the hell is supposed to be connected to the bolt on the starter... i have the plug but cant find anything to attach to the bolt if both of those are ground to the motor/body
There should be a wire from the possitive terminal of the battery that connectc to the bottom of the starter. Thick black wire with a copper o-ring terminal.
· Professional OT Bum
hey I am , are you having issues starting your car aswell?
Also Blackout, on the starter you say theres a positive and negative side terminal, my friend says that the positive side of the starter is the small clip and the ground is the ground.
i guess my question would be is the only positive running to the starter the little clip or should there be pos+ wires that runs there as well?
Anyways after all this changing stuff around and all that im still getting the same issue, 1 click from relay 1 click from starter any ideas
you see the bottom left image, the solid wire is negative and the clip is a positive, so what we did was stick a good electrical grade wire into the plug end of the starter and ran it touching distance to the battery and got it to fire over that way.
but i think u have the same issue we are having with the click but no turn over :freak:
theres your problem, take that little wire that goes to the starter(the one with the clip), and connect a jumper wire to that port, and then thouch the other end to the positive on your battery. you should have it crank by then. reset your alarm if thats the problem.
1 - 20 of 28 Posts
