How much would it cost for a tuner to program a 2 step into my AEM EMS? How do I know if my AEM have the 2 step feature? thanks
A 2-step means a 2 step rev limiter. So you can build boost off the line for drag racing.What is a two step do you mean like a low boost pump gas setting then where you can switch it to high boost with race gas?
Does anyone know a tuner in Socal that can program a 2 step onto my aem? Can I do it myself?
I have never changed anything on aem before. I would need a step by step instruction. hahayou probably do it yourself. Or have you never changed anything in your AEM yourself ?
the 2step setup is here in the AEMPro
Setup>Rev Limiters>2step Rev limiter
it´s not that complicated to set up the 2step. Mine is building about 17 psi(2step ignition cut at 5300rpm)
and looks like this when i use it![]()
http://videos.streetfire.net/search/supra+iceland/0/ceca88cf-f4d5-423f-8484-9900014f02a2.htm
It's a little harder on your exhaust valves, exhaust manifold and turbine wheel depending upon how it's setup and usedStupid question: Does building boost with a 2step have any negative affects on the engine aside from the resulting abuse as it launches from the line? Like does the loud pop & backfire hurt anything?
the two step isnt that hard on the motor, its when you tag team it with anti-lag and retard the timing where its igniting after the exhaust valves are open is when it starts to get hard on the exhaust side of the motor
alpha, you have a ext. dump wastegate or an exhaust leak in that vid of your supra?there is some fire coming underneath your motor
Hey Alpha, thanks for programing the 2 step onto my ecu. :bigok:I will get that calibration to you tonight
Below is a GST converted to AWD with a built 4G64, GT35R, etc. on the AEM EMS 2-step. I will post the video later. Made 20lbs on the two-step
