1 - 20 of 37 Posts
The U.S.-Spec Four-Cylinder Turbo Supra was made official in a press release from Toyota:
Toyota GR Supra Races Into 2021 with More Power and First-Ever Four-Cylinder Turbo Model
February 13, 2020
248201
  • GR Supra 3.0 Gets Power Boost and Revised Chassis Tuning
  • New GR Supra 2.0 is First-Ever Four-Cylinder Version, with 255 Horsepower and Lower Weight
  • New GR Supra A91 Edition with Exclusive Color and Design Features
  • 8-in. Central Display Screen Now Standard on All Models
DAYTONA BEACH, Florida (February 13, 2020) – Brimming with history and reverberating with the echoes of legends, Daytona International Speedway, where the Toyota-powered and sponsored AAR Eagle Mk. III GTP won the 24 Hours of Daytona in 1993, setting a 1:33.875 lap record that stood until 2019, seemed the ideal place for Toyota to launch the next phase of the GR Supra. For 2021, the six-cylinder GR Supra 3.0 models leap ahead with a power boost and retuned chassis, while a new GR Supra 2.0 four-cylinder turbo model joins the line.
The first 1,500 Mk. V Supras were Launch Editions, and for 2021 Toyota is offering 1,000 new A91 Editions. This special edition Supra will have the 3.0-liter inline-six-cylinder engine and will be available in a choice of two colors, Nocturnal or Refraction, the latter exclusive to the A91 Edition and an all-new color for Supra. Accenting the Supra’s concept car-inspired body are a rear black carbon fiber lip spoiler, matte black wheels, C-pillar graphics and carbon fiber mirror caps. The black Alcantara® leather-trimmed interior with blue contrast is likewise exclusive to this limited-availability model, and each A91 Edition will come with two exclusive key gloves and trunk mat.
On the 2021 Supra 3.0 Premium and A91 Edition, the front Brembo® brake calipers are painted red and feature the “TOYOTA Supra” logo. All Supra models for 2021 will feature the 8.8-inch audio touch screen that is standard on the 2020 3.0 Premium model; the base model’s 6.5-inch screen has been discontinued.
The 2021 GR Supra models are anticipated to start arriving at Toyota dealers in June. Here’s what to brace for:
More Power. Because, Why Not?
The 2020 Toyota GR Supra brought the revered model back in a blaze of speed, with acceleration and handling performance that outshone even its illustrious A80 predecessor. For 2021, Toyota is keeping the pedal down, boosting output of the Supra’s turbocharged 3.0-liter inline-six from 335 hp at 5,000-6,500 rpm to 382 hp at 5,800-6,500 rpm, a 14-percent increase. Torque rises from 365 lb.-ft. at 1,600-4,500 rpm to 368 lb.-ft. at 1,800-5,000 rpm.
The increased output results from a slew of upgrades throughout the engine. The new dual-branch exhaust manifold, with six ports instead of two, improves heat management. A new piston design reduces the engine’s compression ratio from 11:1 to 10.2:1.
The greatly revised engine produces higher torque at higher rpm and retains the eagerness to rev with turbine-like smoothness. Toyota projects that the new engine will reduce the Supra 3.0 model’s 0-60 acceleration time to 3.9 seconds, from 4.1. The 8-speed automatic transmission with paddle shifters carries over for 2021.
Retuned Chassis for Supra 3.0
The 2020 GR Supra won praise for its ride/handling balance, but even the exceptional can be improved. Seeking increased roll resistance and enhanced cornering stability, Toyota retuned the Supra 3.0 chassis, adding lightweight aluminum braces that tie the strut towers to the radiator support to increase lateral rigidity, along with front and rear bump stops and new damper tuning. Revised programming for the electric power steering (EPS), Adaptive Variable Suspension (AVS), Vehicle Stability Control (VSC) and Active Differential works in concert with the hardware changes to make the 2021 Supra more stable through quick transitions, such as compound turns.
The First Four-Cylinder Supra Is Quick and Light
The 2020 GR Supra broke from the model’s traditions in several areas, and the 2021 version seems to do it again with the first-ever four-cylinder turbo model. Or does it? The new Supra 2.0 becomes the entry model, returning a two-tier performance lineup that parallels the A70 and A80 Supra models.
The 2021 Supra 2.0 offers an intermediate model between the Toyota 86 and the Supra 3.0, giving the customer three distinct Toyota sports car choices.
The 2.0-liter inline four-cylinder engine shares much of its technology with the 3.0-liter inline-six, including a twin-scroll turbo, direct fuel injection and continuously variable timing on both the intake and exhaust camshafts. The variable intake valve lift system adjusts intake valve timing and duration. The bottom line is 255 hp at 5,000-6,500 rpm and a stout 295 lb.-ft. peak torque at 1,550 to 4,400 rpm.
The Supra 2.0 uses the same 8-speed automatic transmission as the 3.0, and Toyota projects 0-60 mph in 5.0 seconds, which will make it Toyota’s second quickest vehicle in the lineup. The Supra 2.0 has the same electronically limited 155-mph top track speed as the 3.0, and its fuel consumption will be lower.
The Supra Lightweight
The 2021 Supra 2.0 offers much more than a lower price point. At 3,181 pounds, it is more than 200 pounds lighter than the Supra 3.0 while maintaining that model’s exemplary near 50:50 weight distribution. That’s because the weight reduction is spread throughout the car:
  • The Supra 2.0 uses smaller front brake rotors than the Supra 3.0 (330mm x 24mm vs. 348mm x 36mm), and with single-piston calipers vs. four-piston.
  • The Supra 2.0 does not have the Active Differential and Adaptive Suspension used on the 3.0 model.
  • A four-speaker audio system is standard, vs. the Supra 3.0’s 10-speaker system.
  • Supra 2.0 seats are manually adjustable, vs. 14-way power-adjustable in the 3.0.
The Safety and Technology Package is new for MY21 and will be available on the 2.0 and 3.0 grades. That package includes:
  • Dynamic Radar Cruise Control (Full speed)
  • Blind Spot Monitor (BSM)
  • Rear Cross Traffic Alert (RCTA)
  • Parking Sensors with Emergency Braking Function
  • Navigation
  • 12-speaker 500-watt JBL Audio System
  • Wireless Apple CarPlay® compatible (iOS only)
  • Supra Connected Services: up to four-year trial includes Remote Services, Remote Maintenance, Automatic Emergency Call, Real Time Traffic Information, Concierge, Stolen Vehicle Recovery, and Map Updates.
The Driver’s Assist Package will still be an available option on the 3.0 Premium and A91 Edition. That package includes:
Straight to the Racetrack
Customers don’t have to wait long to get their hands on the new GR Supra GT4, as it will go on sale in the U.S. starting in August. It is based on the GR Supra and is developed and produced by TOYOTA Motorsport GmbH (TMG).
A three-liter inline six-cylinder engine with single twin-scroll turbocharger has been tuned to 320kW (430hp) with a 7-speed sports automatic transmission with paddle shifters and the mechanical limited slip differential driving the rear wheels. An Akrapovič exhaust system will be fitted and Ravenol will provide first-fill lubricants.
The front splitter and rear wing are made of natural fiber composite, contributing to an overall weight of 1,350kg (2,976 lbs.). Following the specification of the GR Supra road car, the front suspension will be MacPherson strut, and rear suspension will be multilink with KW dampers at the front and rear.
The braking system is enhanced using a dedicated brake caliper for racing, six-piston front and four-piston rear, while running on Pirelli tires.
Safety will be a priority and the GR Supra GT4 will be installed with a high-strength roll cage on the lightweight steel body, and an FIA-standard racing seat with six-point harness. The interior will feature a carbon fiber instrumental panel with a display and steering wheel specifically designed for GT4 competition.
iSPOOL
A91? Really?
248202
Moderator
Why the heck would anybody buy a 2020 when the 2021 "New and Improved" version is coming in a few months.
I don't believe the power gain is 47hp, it's probably less. It's just an attempt to get more attention, look what we did here!
Like we said earlier anybody paying over sticker is a fool, but even paying sticker is foolish, your cars just depreciated with 2021's arrival.
Way to go Toyota! /sarcasm
They should have put the higher factory HP in it the first time around. Guess the 2020's will take a bigger hit than expected as new buyers will go with the 2021 with more power stock.
Doesn't the 2019 Z4 have 382HP? Toyota really is saving some dollars by using all the leftover BMW engines. Next year they might even offer the 404hp overboost option lol. Disappointed no 6 speed option even for the 4 cylinder either:/ Still kinda heavy for a 2 seater but not horrible.
Blue Thunder
The GR86 with a flat four turbo with 220-255hp will DECIMATE all Zupras...with a turbo upgrade ! AND it will have a 6spd AND back seats !!! Muhahaha
Oh, just wait until they've exhausted all the little stupid things masquerading as improvements.
Tada is going to release an orange SUPER DUPER FAST AND FURIOUS VERSION!!
COLLECTOR CAR!!
LIMITED PRODUCTION!!
Just. Watch.
JetFire
Is the GR86 actually happening? I wouldn't say all Zupras either ha ha. Maybe the 4 cylinder ones.
Anime Dork
That's what they will be calling the new 86 here for the states and the motor they are looking to use is the motor out of the Subaru ascent which is currently make 260 hp turbo flat four. So if they end up using that motor like the rumors are pointing too i'd imagine it might be in the 250 hp range vs the 260 hp that its currently rated at in the ascent
iSPOOL
I would like to know how both those Zupra trims manage to keep the 50/50 balance with one being 220lbs lighter. I can feel the difference in weight with our 1998 Supra Turbo vs NA driving down the road.
Boost Junkie
Haha, they made it even less desirable by adding the 4 cylinder option. Toyota really has no clue.
Steve
Moderator
2020 owners are not happy on other forums I am on. I don't blame them, but they have to remember it's just a car to Toyota. Like a new Corolla or Highlander it's something they do a new one every year. Despite the faux excitement, it's really just a car to them and nothing more.
Blue Thunder
It's happening. They already have been testing the motor in test mules. Plus Toyota has given the 2nd gen 86 a go
for production. I don't think it'll be close to hp as the 4cyl Zupra. But that's what upgrades are four. And like Tada said
"If you want a stick, get the 86".
I had no idea that this was even a thing.
Shows how disinterested I have become with Toyota in recent times as part of my vehicular existence.. it's sad.
So Toyota can produce the Zupr4, a new Carolla hatch and a new 86 but can't get together on something that will actually amount to something and become a remarkable moment in their history.
K.
1 - 20 of 37 Posts
