1 - 8 of 8 Posts
I just got done mounting 28" Goodyear slicks on the supra and there was only a small gap between the tire and the fender well. Did you guys have to roll the fenders to fit these?
King of the NA-T's
I run Goodyear 28x11 and I trimmed off a fair amount of the fender lip to get clearance.
28x11,5's on N/A wheels. YES, you have to trim the fenders quite a bit. If you don't you need to keep the car from squatting the tire into the wheelwell.
19in 795R HRE's FTW....
I have a set of 28x11.5x15 ET Streets with 5 passes for sale. $150ea
You don't have to trim that much depending on the offset of your wheels
its a slow auto...
I would say most peope who step up to a 28 inch tire would be running the correct backspaced wheel, the issue would be more so that every tire is different, your et street says its 28 x 11.5 and its actually smaller then daves 28x11..
your et street has a 11.1 section width,8.6 inch tread,and is only 27.6 inches tall with an 87 inch roll out...
daves tire he listed above has a 12.5 section width,10.7 tread,28 inches tall with a 88 inche roll out.. :)
jay
Mine are 28x11.5x16 Hoosier quicktime Pro's on stock N/A wheels. I run stock T/T brakes. Wheels need a little massaging, and so do the calipers. Just a little shaving to make them fit.
1 - 8 of 8 Posts
