1 - 9 of 9 Posts
On my trd WB I'm currently running Michelin Pilot Sports
18x10 +24 with a 275/35/18 front
18x12 +10 with a 335/30/18 rear
I have a pair of 295/35/18 Michelin PS. I'm debating on running these on my fronts. Question is will they fit on a 10 inch rim? If so how will it look? Anyone running this combo? Pics would be great.
· Premium Member
They're too tall and will rub the fender liner at full compression.
The 295 will fit a 10" wheel, but it does appear to bulge out a little.
A 295/30R18 would be a better fit visually if you don't mind the look.
Later, Steve
Hey Steve, while you're at it, Can you help answer this question for me? I currently have 19x8.5 front and 19x9.5 rears.
I'm thinking about wrapping them with 235/35ZR19 front, and 275/30ZR19 back. Will there be any rubbing? I have stock suspension.
'94 TT 6 speed.
Thanks in advance
· Wheel Fitment Guru
'94 TT 6 speed.
Thanks in advance
Unfortunately we need your wheel offsets to determine that.
R.K.
· Suprasarous Y0!
At 285 30 18 you are already pushing your luck depending on how low you are. For me I needed to roll the fronts and I sometimes still hit the inner fender wall on a good bump. Adding a wider tire and bigger side wall would definately make contact. If i were to do it all over again i'd even go with a 275 tire.
The info above is based on a CCW wheel which has spot on offset.
1 - 9 of 9 Posts
