Will it work w/ a 1JZ? I bought the 2JZ water pump just not sure if the belt will line up properly.
NDBoost · mount /dev/disk1s10 FFUU Joined May 10, 2005 · 903 Posts Discussion Starter • #1 • Apr 18, 2007 Will it work w/ a 1JZ? I bought the 2JZ water pump just not sure if the belt will line up properly.
NDBoost · mount /dev/disk1s10 FFUU Joined May 10, 2005 · 903 Posts Discussion Starter • #3 • Apr 18, 2007 okay how about the rear timing plate cover the one that goes between the cam gears and head. can you get that from a 2jz?
A annoyingrob · Now with 0JZ Joined Jun 17, 2005 · 1,185 Posts #4 • Apr 19, 2007 zoonwen said: yes it will work Click to expand... if he doesn't have a hydro fan.
zoonwen · MK3 Owner For Life Joined Oct 21, 2004 · 1,822 Posts #5 • Apr 19, 2007 (Edited) He was askin if the pully on the 2jz waterpump he just got will line up the same as the 1jz pulley. =D annoyingrob said: if he doesn't have a hydro fan. Click to expand...
A annoyingrob · Now with 0JZ Joined Jun 17, 2005 · 1,185 Posts #6 • Apr 19, 2007 zoonwen said: He was askin if the pully on the 2jz waterpump he just got will line up the same was the 1jz pulley. =D Click to expand... I can't read FTW. haha.
