1 - 7 of 7 Posts
yeah thats me!
any of you guys with the aristo/supra engines have any issues with keeping AC
in the car?
it is hot as all hell here in FL in the summer and AC is a must.
Just wondering what difficulty you guys had keeping it.
-ian
my AC works just like factory intended in both my 1JZ swapped sc300's. Used the stock 2JZGE compressor on one car. Other has the 1JZGTE oem one. plugs and hoses bolted right up. 2jzge, gte and 1jz, supra MK4, soarer, and sc300 AC compressors are 100% interchangeable.
yeah thats me!
i know sc300's are the easiest car to perform the swap, but see sig.... 2jz is going in that bucket.
I had to do the mod that is half 7m and half 1JZ on the compressor so that it would mount up to the stock lines in the engine bay.
yeah thats me!
what mod is that?>
Is the 1JZ bottom end and 7M top end to the compressor. So that the lines meet up on top of the compressor with the lines inside the engine bay.
if you're asking specifically about a 2jz into a mkiii, yes it's not too hard to adapt the lines from the 7m set up.............just interchange the top of the compressors where lines bolt up, after that once engine is into engine bay you will have to slightly bend ac lines so as to find the right angle for everything to bolt up
1 - 7 of 7 Posts
