1 - 3 of 3 Posts
Hi, I need to know what kind of sensor does the 2jz on the supra tt uses. is it a hall effect sensor or a magnet sensor, and does the supra uses the same 24 tooth magnet sensor like the other toyota cars (ex, 4AG, 3SGE).
thanks
The 2JZ uses magnetic sensors, like most other Toyota engines. Instead of a 24 tooth wheel driven by the camshaft (to produce the crank position signal), the 2JZ uses a 12 tooth wheel on the crankshaft, which produces a signal similar to other Toyota engines.
Are you getting ready to hook up an EMS?
1 - 3 of 3 Posts
