1 - 13 of 13 Posts
So for some strange reason I had rod knock on first startup when the engine was cold. It took about 3-5 seconds to build full oil pressure. I am not sure why, but it might be because the oil pump would lose it's prime. Engine is a rebuild(I did not replace the pump though)
Anyway....
I pulled the motor so I could check the bearings, and since I was changing the tranny, and the oil pump, it doesn't take much longer just to pull the whole thing.
So I pulled all the bearing caps to inspect and what I found is ALL of the bearings were almost PERFECT.....all but one.
#4 Rod bearing looks like it has been pretty hammered. Somewhere I have pictures of the plastiguage when I was building the engine for a comparison.
So, why would #4 be messed up and the rest of the engine is great if the clearances were all the same.
Is it a rod bearing, or a main bearing that went? As the picture below shows all the mains.... We dont have 7 connecting rods, unless you have some freak motor :tongue:
Here is the bearings with plastiguage during the build.
Why was the engine rebuilt in the 1st place? The oil pump can hold old bits of metal shaving created when you spin a bearing and it along with the oil cooler should be changed if that was the problem before. #4 probably got that way from some odd substance in the oil.
hmm since the number 4 main bearing is in the middle doesnt it take the most beating under load because of the unsupported weight in the middle ?
Boost4fun
There is no unsupported load in the middle since the load is divided evenly on all bearing being one before and after every rod.
I would re-measure the crank and ensure that the size is according to spec and interchange the bearing... That has to work out.. Otherwise something else is wrong.
Discussion Starter #8
Well, I have everything down at the machine shop right now getting re-measured. Hopefully we can find something. If not, I blame the oil pump.
Does anybody know the path of the oil. What I mean, is under low oil pressure, what bearing would have the least pressure?
I love sequentials!
That looks like an oiling problem to me, not a debris issue
If you want to be really anal, dip and clean the block and crank, replace the oil pump with a new one
Discussion Starter #11
Yes, i am replacing the oil pump. I really think that was my problem, and for some reason #4 was the one who took the hit. I already had the block cleaned once, it i getting cleaned again and having the line bore/runout/damaged crank checked.
Yes I used assembly lube. In fact there was still assembly lube under the bearing in the oil passage grove. Hmmmm, that shouldn't not have been there now that I think about it.
Discussion Starter #12
My block check out ok for line bore.
I am still waiting to hear back on the crank. Probably tomorrow.
I did check the runout(although I did it wrong) with the crank was in the block. All but #4 were torqued down. I measured only about .0002, which is well past what I can accuratly measure. Bust, seeing there were no signs of excessive wear in #3 or #5, I don't believe runout would be a problem at all.
Maybe this was just some freak thing. I know for a fact my clearances were good. I measured twice with guages/calipers/indicators, and twice with plastiguage, and it was all good.
1 - 13 of 13 Posts
