Bought my wife an 89 Cressida a few years ago with about 120,000 miles on it, leaking oil from every orifice possible. The previous owner spent a bunch on new water pump, timing belt, etc etc trying to track down the culprit. Turned out the breather tubes on the 7m were clogged. After unclogging, the car ran great and oil leaks went away. Car has been our daily and cross country car; driven ALL OVER the US, from Florida, to Ohio, to Wisconsin, to Washington state, Cali, Colorado...everywhere. Went thru 1 headgasket, and 1 transmission and now has over 200K miles and has been smoking a little on startup and drinking a quart of oil every other fill up. Also one spark plug hole has been damaged and repaired, but its not holding well so it's on borrowed time.
Picked up a decent looking 2JZ/auto out of a 95 GS300 to throw into it because she loves this car so much, we can finally get rid of the lame 7M. I've already collected the power steering hose for the swap, engine mounts, replaced the timing belt with a Gates Kevlar belt, new water pump, LS400 fan clutch, new plugs, wires, dizzy cap and rotor, O2 sensors, and bought an Ebay header for it. Turns out the engine is a California emissions model, which we're moving out west soon too, so I'm going to leave all the emissions garbage in place so it passes any tests fine. Tore the engine down a bit as the intake manifold was gunked up pretty bad inside and cleaned everything up decently. Injectors are going to get cleaned/tested next week and I've got silicone vacuum hose enroute to replace all the old hoses on the engine. Wanted to throw on a set of valve stem seals, but I think that's more of a TT/GTE issue than a GE, plus I just don't have time to mess with that right now. I think next week the engine will be buttoned up and ready to go. I've also swapped over the Cressida top hat and hoses on the A/C compressor.
The next issue is the trans, the Cressida A340 is missing a few things compared to the Lexus GS300 A340, so the plan is to build a hybrid A340 and rebuild it at the same time. I bought a real nice "Stage 1" rebuild kit with upgraded Raybestos clutches that'll go in while I basically turn the Lexus A340 into one that can drop right into the Cressida in hopes that I don't have to change the driveshaft. The Cressida trans has a different output/tail shaft, and a different speedometer sender than the GS300. The problem with that is the back part of the trans is the last piece to get to when you disassemble them, so you have to take it apart entirely to swap these pieces around. I've rebuilt the A350E trans in our '96 GS300 a few years ago, so I know how to work on these things...so long as you've got a clean work space and various snap ring pliers, it's not too terrible...there are a couple of tough spots where a 2nd set of hands helps a lot though.
Anyways, just thought I'd share what I'm about to do. I may be digging around for help when I get closer to executing the swap. Have to finish the trans first. In the end, hoping to have a better running, better gas mileage, and more powerful engine in her car...should be do-able. With the header, it'll easily put out a good 25 more horsepower than the tired 7M. The 7M currently gets a max of about 22 mpgs. Our much heavier GS300 gets about the same or slightly better, so I'm hopeful that the Cressida with the 2J should put it somewhere in the 25-26 range if it's running right. I don't think I've ever gotten the advertised 25 mpg on any 2JZ car I've ever owned though.
I'm trying to think if there's anything else I want to do to the engine before I button it up, but I think it's ready to go. Any suggestions? Not deleting any emissions equipment. Anyone got any other Cressida 2JZ-GE swap tips?
