On my website www.mkiv.co.nz there is a 2JZ-GTE injector size calculator that I have written that allows you to estimate the injector size you need for your 2JZ-GTE engine. It takes into account the RWHP or RWKW you require, the A/F ratio, the dyno type (US mainly use DynoJet), transmission type, fuel regulator rising rate and base fuel pressure and the injector duty cycle.
Check it out at www.mkiv.co.nz/injectors.htm
I think its pretty accurate, but any feedback to improve the accuracy of the calculator even further would be much appreciated.
Nice site, I bookmarked it too. But I have nothing useful to add or edit on your injector calculator.
