1 - 4 of 4 Posts
I was wondering what is the difference between the 2jz gte from the supra vs the 2jz gte for the aristo?? Please help.
off the top of my head the aristo has smaller injectors 440cc,smaller cams,front sump oil pan set up, i believe they all come automatic not sure
JDM Supra vs JDM Aristo, nothing internally. Externally, there is no banjo bolt on intake manifold for the brake booster, no dash temp gauge single wire sender on the Aristo motors; front vs rear sump, different AC compressors, different Oil filter housings. Non-VVT-i motors have different water pumps and housings.
USDM vs JDM has been covered so many damn times that if you google USDM vs JDM 2jz, it will give you all the info you are asking to be spoon fed.
1 - 4 of 4 Posts
