JZA80
Hey Curt,
Have a small project going and need the following:
- Full OEM Gasket Rebuild Kit
- TRD Oil Cap
- All OEM Timing Belts
- OEM Oil Pump
- OEM Oil Dip Stick & Tube
- OEM Coil Packs
- OEM Oil Filter
- OEM Slave Cylinder
- OEM Idle Air Control Valve
- OEM Upper & Lower Timing Belt Covers
- TRD Thermostat
- OEM Idler Pulley (full assembly)
Thanks!
JZA80
Knew I forgot something...
Turbo (2JZ-GTE)
04111-46094 gasket kit list 549.28 cost 410.00
ptr04-12108-03 cap oil trd list 81.03 cost 72.07
13568-49036 belt, timing list 35.58 cost 27.17
15100-46052 pump assy oil list 226.88 cost 170.00
11452-46060 guide, list 22.58 cost 17.23
15301-46023 dip stick list 14.60 cost 11.15
90919-02205 coil, ign list 126.57 cost 95.00 ea x 6
90915-yzzd3 filter, oil list 5.41 cost 3.90
31470-14060 cylinder slave list 82.74 cost 63.17
22270-46060 valve assy list 601.00 cost 450.00
11302-46031 cover belt lwr list 59.59 cost 45.49
11303-46011 cover belt middle list 65.48 cost 49.99
11304-46050 cover belt top list 130.58 cost 99.70
ptr04-00008 trd tstat list 84.99 cost 74.49
16620-46070 tensioner assy drive belt list 239.70 cost 183.01
13505-46041 idler t/belt list 91.11 cost 69.57
13540-46030 tensioner t/belt list 77.42 cost 59.12
all in stock
JZA80
What would shipping be to 85233 for all of those?
Or, do you think I should just ditch the shipping and head down to my local Toyota? (As these items are pretty common)?
Thanks again Curt,
