1 - 2 of 2 Posts
Hi guys,
I am owner of a Supra jza80 TT, JDM spec, v161 and A03b differential. Since I have a second differential A03b that I don't use, I want to use it to mount a 2-way lsd, and a shortened final drive. I wanted to know if it is possible to install the 3.77 final drive coming from the Supra differentials of the model with automatic transmission A02b or A02a. Are they completely plug and play? alternatively do you know of some site where to find the final drive for A03b and the relative rigid collar to use instead of the original one?
Thanks in advance
very sure they are all plug and plug. I just swapped my R200 (non turbo diff) into the Subframe without changing axles and it was fine. Speed reads perfect as well, but I also swapped in a V160.
1 - 2 of 2 Posts
